Discussion topic: Conversion leads
This message was authored by: ollie20
Conversion leads
Do you need to change the leads on your broadband when you change to sky broadband superfast
Re: Conversion leads
@ollie20
If it's a Superfast speed band arriving over FTTP then an ethernet cable is required between the Optical Network Terminal and the Hub.
