Discussion topic: Internet connection
Message posted on 05 Jun 2025 10:47 AM
Internet connection
Message posted on 05 Jun 2025 10:54 AM
Re: Internet connection
@Clare-1234
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
