Discussion topic: Internet connection
This message was authored by: NathanCooper
Internet connection
Trying to watch something on amazon prime. Continuously stopping and buffering
Re: Internet connection
@NathanCooper assuming other devices are behaving normally the most likely issue is a poor WiFi connection to the device you are streaming through. You can check the speed most strreaming devices connect at by running the useful Network test in the Netflix's app Get Help menu. Streaming video requires a good stable connection so if the wifi is in any way dodgy you will get buffering.
