Discussion topic: Internet connection
This message was authored by: IoanaDaniela
Internet connection
Hello. My Internet doest work properly. Can you please check and fix it ? Thank you
Re: Internet connection
@IoanaDaniela
This is a customer helps customer forum.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
