Discussion topic: Internet connection keeps dropping
This message was authored by: Shaunie_leanne
I have reset at the wall and the router but it keeps dropping. Service checker says no issues but why is it still having an issue.
Re: Internet connection keeps dropping
@Shaunie_leanne Take it one step further and run the diagnostic as linked below!
Try running the line test here to see if any faults are found:
This message was authored by: Matt340
I'm getting the same issue.
All comes back green no problems, but won't connect
@Matt340 All 4 lights go Green?
This message was authored by: Pamula
I'm having same issues. All diagnostics come back fine
I phoned sky.
They were able to resolve remotely.
@Matt340 are you able to advise @Pamula what was done if you know?
I finally got through to a person myself and they did some checks. Said it was an external line issue and they would send an engineer.
Hopefully sooner rather than later!
@Pamula All you can do is keep an eye on all the text's etc and your account orders should also show!
