Discussion topic: Internet connection, it says we don’t have 1
This message was authored by: Internet7
We do not have internet connection right now
Re: Internet connection, it says we don’t have 1
@Internet7
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
