Discussion topic: Sky fibre
Message posted on 03 Oct 2025 11:47 AM
Sky fibre
Message posted on 03 Oct 2025 12:21 PM
Re: Sky fibre
@tai-pan66 Which sky Hub do you have now?
Message posted on 03 Oct 2025 01:23 PM
Re: Sky fibre
The SR203 Sky Broadband Hub from 2019 is compatible with FTTP and Sky Talk Internet Calls.
Message posted on 03 Oct 2025 01:31 PM
Re: Sky fibre
I have the black sky broadband hub.
Message posted on 03 Oct 2025 01:37 PM
Re: Sky fibre
Then if you don't choose to add the WiFi Max subscription supplement to the account Sky probably won't send a replacement.
Message posted on 03 Oct 2025 01:40 PM
Re: Sky fibre
@tai-pan66 They should send you the required Ethernet cable that you WILL need to connect the Sky Broadband Hub to the new ONT that will be installed for your Fibre Install!
