Discussion topic: Internet connection down
Message posted on 15 Sep 2025 05:36 PM
When I go onto settings on my skybox it says the Internet connection is down yet when I check the services via the Sky app. It says that everything is working. We do not have any access from any devices to the Internet and the multiple boxes cannot either access the Internet
Message posted on 15 Sep 2025 05:39 PM
Re: Internet connection down
@Toni.Display
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
