Discussion topic: Internet connection down
Message posted on 25 Aug 2025 01:48 AM
Message posted on 25 Aug 2025 02:21 AM
Re: Internet connection down
Lodge complaint with sky. If within cooling off period. Cancel
Message posted on 25 Aug 2025 05:35 AM
@Lorna83
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
