Discussion topic: Internet connection doesn’t work on phones
This message was authored by: SofiaBarbeitos
Internet connection doesn't work on phones and is weak on tv
Re: Internet connection doesn’t work on phones
@SofiaBarbeitos modern phones will switch to use mobile data if the wifi connection is poor you can alter this by turning off a setting called WiFi Assist in mobile data settings on iPhones modt Android phones have a similar setting.
If WiFi signal is poor in your home check your hub is in the nest position which is out in the open on a surface so it is aboce obstructions like radiators. Otherwise you need to get extra Wi`Fi kit which Sky will provide if you buy their https://www.sky.com/help/articles/sky-wifi-max
Alternstively you can buy and use your own WiFi kit.
