Discussion topic: Internet connection disabled with VPN
This message was authored by: Thottappilil
When VPN is switched on, internet connectivity is disabled. It is working fine when there is no VPN. This issue started occuring only recently. Until the begenning of June 2026, internet connectivity was working fine when VPN is enabled. But not now. Can anyone suggest a solution please.
Re: Internet connection disabled with VPN
@Thottappilil given the internet connection is via the VPN when it is being used suggest you talk to whoever runs the VPN.
