Discussion topic: Internet and wifi gone again
Message posted on 26 May 2025 07:41 PM
Is anyone elses wifi and internet fown again
Message posted on 26 May 2025 07:43 PM
Re: Internet and wifi gone again
@Annie302
For a broadband issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
