4
This discussion topic has been answered Discussion topic: Internet amber light
This message was authored by: Gpj1
Internet working all day now just dropped off. Amber light for Internet. MySky tests say Internet all ok. I have followed the connection diagnostics all don't help solve the problem.
Re: Internet amber light
@Gpj1
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@Gpj1
This message was authored by: Taz82
Mines done the same! It's been down since about 4pm!
seems there are lots of similar posts about this same issue
Is yours working again?
@Taz82 at any time you will read posts from people whose connections have failed as with 5 million plus customers that is inevitable. Chances are unless you are in the exact same area as another poster the two issues are not related . Therefore you need to go through the steps advised by @Daniel0210.
Avatar for Gpj1
Thank you all
it transpires this affected more people locally so was an outage. All back up and running without needing to do anything. not sure how sky connected to my router during the outage and say all is ok but there you go.
