Discussion topic: Internet Not Working
Message posted on 19 Apr 2026 12:22 PM
My broadband has not been working properly since 10:30 this morning. When I do an online check it says everything is okay but the router is either flashing amber or solid amber. It will then go green but only for a few minuets.
Message posted on 19 Apr 2026 12:23 PM
Re: Internet Not Working
@ryculff
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
This explains the lights on the hubs:
If you have Sky Fibre and your ONT shows a red light then have a read of this:
Try running this line test to see if it finds any faults:
