Discussion topic: Internet Connections Problems
This message was authored by: elvis811
Message posted on 16 May 2026 12:25 AM
I always have internet connection problems; I often think I should change the router because I've had it for 10 years and it doesn't work properly.
Find out more
Message posted on 16 May 2026 04:42 AM
Re: Internet Connections Problems
These are the Sky hubs currently in use. The last two- the Sky Q hub and the Sky hub are being actively replaced with Sky sending out emails/letters to customers.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Find out more
Message posted on 16 May 2026 05:39 AM
Does it let you order a free replacement one via here:
