Discussion topic: Intermittent wifi
This message was authored by: Jessiej170
Intermittent wifi
Internet keeps going off and app says no issues
This message was authored by: Nsta
Re: Intermittent wifi
Mine too - assume their fix this morning has broke again
Monday 15th 4.35 - internet has gone down yet again - this is now the 4th day affected - what on earth is the problem?
@Jessiej170
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Nsta
i provided this advice to you yesterday.
