Discussion topic: Intermittent broadband
Message posted on 15 May 2026 12:22 PM
The broadband regularly is lost on Sunday afternoon when I am streaming, consistently around the same time.
Also, this week it has been regularly cutting out during daytime, losing Alexa and my partners connection for meeting.
Message posted on 15 May 2026 01:12 PM
Re: Intermittent broadband
Do you have a weak signal throughout your home or does the lights on the broadband go out or start flashing when you have no connection ?
Message posted on 21 May 2026 09:34 AM
Hi @caesarome, no, all the lights are green. The signal just drops so I can lose Alexa, a stream, etc several times in a day.
Message posted on 21 May 2026 09:45 AM
@PaulRochie wrote:Hi @caesarome, no, all the lights are green. The signal just drops so I can lose Alexa, a stream, etc several times in a day.
Sounds like a WiFi issue, have a look at the following and the associated links to try and get sufficient signal with your existing setup.
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Not a Sky employee
Sky FTTP 500Mb to Max Hub
