Discussion topic: Intermittent Wifi Connection
This message was authored by: araja88
WiFi has been on and off over the last two to three weeks. We had put in a complaint a couple of weeks back and Sky had sent an engineer as there was a problem detected outside of the property. Since then it hasn't really improved. There is definitely itelt a problem somewhere and it needs to be fixed!
Re: Intermittent Wifi Connection
@araja88
I would suggest calling them about this so they can run some checks on your line and if the fault is still there then an engineer should be booked for you again.
