Discussion topic: Intermittent WiFi connection
Message posted on 07 May 2025 04:52 PM
Message posted on 07 May 2025 06:18 PM
Re: Intermittent WiFi connection
@Mrsp1983 From the link below which router do you have.
Message posted on 07 May 2025 09:11 PM
Hi,
It's the Skybroadband hub.
Message posted on 07 May 2025 10:45 PM
@Mrsp1983 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
