Discussion topic: Interent box flashing green light
Message posted on 16 Dec 2025 05:47 PM
Message posted on 16 Dec 2025 06:04 PM
Re: Interent box flashing green light
@Emmabrunt18 The help info to what you are seeing is below, also 2nd check to possible reason!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
and/or
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
