Discussion topic: Incorrect password
This message was authored by: QWiFi
Message posted on 19 Dec 2024 05:27 PM
Incorrect password
My WiFi is activated but it kept saying incorrect password
Find out more
Message posted on 19 Dec 2024 05:43 PM
Re: Incorrect password
@QWiFi itvis quite easy to misread the password on the label as Sky will use both the numberc1 and the ketter I and 0 and O.
If you are surecyou havectyped the password correctly reset the hub which will return it to its defaults. The black hub press and hold the reset pin until the power led blinks which takes up ton30 seconds. On thecwhitechub press and hold in thecwps button for 30 seconds then release.
