1
This discussion topic has been answered Discussion topic: Inaccurate wifi test
This message was authored by: W-DHousehold
"Upgraded" to the 500 and Max Hub yet can not get signal in most of our rooms. Currently sat using 5G but when I do the WiFi checker it says your connection looks good, I'm not even using the WiFi! Can we get boosters that will work?
Re: Inaccurate wifi test
@W-DHousehold
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
@W-DHousehold
