Discussion topic: ISP issue
Message posted on 18 Nov 2024 11:53 AM
ISP issue
I can't get on the national lottery website as it says I'm located outside of the UK when I'm not, what can I do to fix this
Message posted on 18 Nov 2024 01:15 PM
Re: ISP issue
@ABC1234 you can try powering down your Sky hub for an hour which will give you a new IP addres which should be UK based. The issue is caused by Sky like other ISPs having to buy small,blocks of IP4 addresses which can be based literally anywhere. The world has run out of new IP4 addresses.
While these adrresses are re-registered by Sky as UK addresses it takes a while before all of the services that check location catch up.
