Discussion topic: IPVanish VPN will not connect since Sat 4th 1100
This message was authored by: Womble1
My VPN service (IPVanish) will not connect.  It stalls on CONNECTING.
I have tried numerous devices, Windows, Mac, IOS, Android and the problem persists.
My first call was with IpVanish and they have been extremely helpful, but everything points to an issue with the Sky Broadband.  To verify this, I used mobile data to connect with the same devices to the same VPN, using exactly the same setup and the connection to the VPN was instant and stable.
I have turned off the Sky Router for 30 minutes to reset - Same issues
I have turned off Sky Broadband Shield (it's been off for over 12 hours now) - Same issues.
Please can someone suggest a solution or can Sky technical investigate from their end.
Thanks!
Re: IPVanish VPN will not connect since Sat 4th 1100
@Womble1 Sky cannot pick up an issue directly from a post. Your's is, as far as I can see, an isolated post and if Sky had an issue blocking VPNs generally there would be hundreds of posts.
When you powered down for 30 minutes did the public IP4 address change? Sky's IP addresses are quite sticky and an issue with your current address could cause an issue. Try disconnecting by using the option in the hub's web interface as that may kick in a change of IP address.
Avatar for Womble1
That's very helpful.
No, the IP address isn't changing after either a power down, or by resetting in the router control panel.  I had assumed that the address would change.
Is there a reliable way to force an IP reassignment?
Also, is there a direct chat facility for getting in touch with SKy technicians?  I couldn't find that.
All suggestions very welcome.  Thanks again.
Avatar for Womble1
From another post on here I tried the following to force a new IP address.
If anyone has trouble finding the button, the full path is:
Maintenance --> Router Status --> Connection Status --> Disconnect (button)
This has changed the IP (quite substantially to a different 'first number') and this has allowed the VPN to connect.
I still don't understand WHY the problem presented itself however.  Why would an IP address be problematic.  IPVanish couldn't find a problem with the inital (faulty?) IP address.
@Womble1
It suggests the IP itself was blocked by IPVansish or somewhere along the route has a problem connecting to IPVanish's server
I am NOT a Sky Employee
This message was authored by: SteveJack
@Womble1
Brilliant! Fixed my problem too. Thank you 🙂
