Discussion topic: IP Adress
This message was authored by: Angelica1974
IP Adress
I need IP Adress Subnet Mask Gateway and DNS Server
Re: IP Adress
@Angelica1974 if you set your device to get the details from the router you do not need these details but
IP address is assigned by the hub's DHCP server  but will be in the range 192.168.0.2 to 192.168.0.254
Subnet mask in 255.255.255.0
Gateway  is 192.168.0.1
Set the DNS to the Gateway addess and the hub will forward the requests to Sky's DNS.
Re: IP Adress
@Angelica1974
In most cases an ISP router will be offering that information by default, and if a client device isn't receiving it then there's a problem somewhere else (such as WiFi being out of range)
