Discussion topic: INTERNET AND VOICE LIGHT AMBER
Message posted on 31 Oct 2025 01:32 AM
Message posted on 31 Oct 2025 03:33 AM
Re: INTERNET AND VOICE LIGHT AMBER
Same here ! 2 times in the past hour!
Message posted on 31 Oct 2025 04:32 AM
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it doesn't come back on and you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
