Discussion topic: I sp
This message was authored by: Ianoakley
I sp
I appear to be having broadband issues, I can reach certain apps. on my iphone but cannot fully utilise there function and have very slow connection speeds. The problem feels to be a broadband issue rather then a phone issue. Can any checks be done to verify that my broadband is operating correctly with regards to its operating width?
Re: I sp
@Ianoakley NO not from a Forum post but you can check it all yourself from the link below! If this is just a new connection for you would suggest you go have a look at the Broadband Shield product in your account to where it is set at!
Sky Broadband Shield | Sky Help | Sky.com | Sky Help | Sky.com
