Discussion topic: I need to disable Wi-Fi on my sky hub
This message was authored by E+Ledwith This message was authored by: E+Ledwith
Hi I have gone to 192.168.0.1 on chrome but it won't accept my password and username . Has anyone any suggestions
Re: I need to disable Wi-Fi on my sky hub
@E+Ledwith  You can find the information on how to login to the router you have in the pictures below.
E+Ledwith
I got in but when I change strings the site crashes . Did anyone else have this issuer? Thanks
E+Ledwith
Thank you I got in now when I remove the ticks and try to update the site crashes . Do you know if this is what normally happens is there a way past it ? Thanks in advance.
@E+LedwithAre you trying to do this via a device using Wi-Fi or is this device connected via a wired device.
@E+Ledwith what happens is you apply the changes the hub reboots so you lose connection while that happens if using ethernet then you get connection back after a few minutes if using wifi guess what no connection if you have turned off the wifi.
If using an ios device often changes often dont stick so use a device using Windows or failing that Android
