2
Discussion topic: I need cables moved outside house
This message was authored by Jedson77 This message was authored by: Jedson77
Hi, we are having work done at the house next week and just spotted the cable from the junction box comes up in our porch, which is where the work is being done. Is that something Sky would need to organise or do I need to call BT?
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: I need cables moved outside house
@Jedson77
You would need to call sky to arrange any work that involves openreach equipment
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
@Jedson77
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
Any upcoming change to FTTP may be something to consider when deciding on routing cabling, OR usually follow existing paths but do like "simples" IMO.
Passing on the tips I have learned in over 24 years as a more than satisfied Sky customer.
