4
Discussion topic: I need a longer hub cable
This message was authored by Pekb This message was authored by: Pekb
Sky hub cable not long enough
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: I need a longer hub cable
@Pekb
Is this the cable with the purple plugs that goes into the back of the hub (purple socket
That is a dsl rj11 to rj11 cable that you should be able to get from currys, dixons, pc world for around £5
@Pekb
@PekbWhich cable are you referring to? Is it the power cable or Purple ended cable, black or grey?
Pekb
Thank you but it has a purple connector to the hub and a white telephone like connector to the phone socket
@Pekb
Are the plugs at the end of the cable the same or different types. Do you have a photo you can upload?
Do you want the router further away from the master socket or do you want to move the phone further away from the master socket
