Discussion topic: I'm having continuous connection WiFi problems.-
Message posted on 26 Dec 2025 07:02 PM
Daily problems with WiFi dropping out
I pay for this NOT to happen
Fix it
Message posted on 26 Dec 2025 07:29 PM
Re: I'm having continuous connection WiFi problems.-
@Kangie
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
Message posted on 26 Dec 2025 07:30 PM
@Kangie The community Forum is NOT sky customer service, your demands will be better met by the likes of sky, so call them 150 on your landline 8am to 8pm are the opening times and think they are back to normal operation tomorrow onwards again!
