Discussion topic: I have no wifi
Message posted on 10 Jul 2026 03:49 PM
I have no wifi
My broadband has stopped working
Message posted on 10 Jul 2026 03:57 PM
Re: I have no wifi
@Tracey19741
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
