Discussion topic: I have no wifi
This message was authored by: Phivie
I have no wifi
I have no Internet for the last few days. I checked a couple of weeks ago, and there was a problem in the area. Today, the router is still giving a white light
Re: I have no wifi
@Phivie
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
