Discussion topic: I have no broadband or tv
This message was authored by: junglebhoy
Tv and broadband are down
Re: I have no broadband or tv
@junglebhoy
If broadband is down then by definition Stream won't work.  If you have Sky Broadband it's best to post in that forum.
@junglebhoy  As indictaed by @TimmyBGood  if your broadband is down then so will your stream puck as it streams over your broadband.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
