Discussion topic: I have no Internet connection
This message was authored by: Danijc
my devices find broadband that says no Internet. It has been like this for a few hours already.
can I please have an engineer sent as I work from home
Re: I have no Internet connection
@Danijc
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
