Discussion topic: I cannot use my mobile with sky broadbannd
This message was authored by: Jennifer492
Message posted on 19 Mar 2026 04:07 PM
Mobile will not connect to sky broadband
Find out more
Message posted on 19 Mar 2026 04:14 PM
Re: I cannot use my mobile with sky broadbannd
What is happening, so if you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
