Discussion topic: I cannot connect my sky hub
This message was authored by: Sonia76
I have a new hub and it doesn't connect
Re: I cannot connect my sky hub
@Sonia76
It should just work when you have plugged it into the mains and plugged the cable in the back of it so what is happening do you have no lights lit up on it ?
Avatar for Sonia76
Level 0 icon
It doesn't work
it's plugged in but no grewn light starts
Avatar for Sonia76
Level 0 icon
It doesn't work. I have plugged in
