Discussion topic: Hub
Message posted on 05 Feb 2025 09:15 PM
Hub
My signal is slow
Message posted on 06 Feb 2025 07:17 AM
Re: Hub
@paulam67 assume you mean the WiFi signal is giving slow connections. First step is to check your hub is in the best position which is out in the open on a surface so its signal is not being blocked by radiators or furniture. If it is the wifi signal is affected bybthe layout and type of construction of your home. Thiis means that a small traditionally built house with solid internal walls can be more difficult to network than a large modern house. Many homes need more than a single wifi source to get uss blecwifi in every room.
Sky sell a bundle that gives limited guarantees for WiFi speed in every room and can offer up to 3 WiFi extenders if these are required see https://www.sky.com/help/articles/sky-wifi-max or you can buy your own whole home WiFi set up,if you prefer
