Discussion topic: Hub size
This message was authored by Sportsman41 This message was authored by: Sportsman41
Hub size
Just recieved my new hub and it is too high to fit between kitchen cabinet and ceiling, Hub 17cm and gap 7cm. Would it be ok to place in a kitchen caninet?
This message was authored by Sky-2022 This message was authored by: Sky-2022
Re: Hub size
Hi, @Sportsman41.
This link may help in someway - https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Sky Q UHD 1TB (on ethernet) & Sky Superfast - SR203 router (59mbps downstream, 16mbps upstream - average)
If my reply is correct/up-to-standard mark it as answered.
If I get it incorrect, educate me - I am open to learning from others as we are one community.
If I say something you find informative and helpful give me a thumbs up.
I am trying to level my way through progressively 🙂
Re: Hub size
@Sportsman41
Short answer is no, you'll likely reduce WiFi range & throughput drastically as well as possibly overheat the hub is there isnt enough fresh air flow to passively cool it
I am NOT a Sky Employee
