Discussion topic: Hub set up
This message was authored by: Ata1
Hub set up
Hi,
I've received my sky max hub today, and there is only a routeter and a charger in the box, i don't know how to connect it to the phone line. There must be a cable for the connection
Re: Hub set up
@Ata1
Work through the steps in the video here: https://www.sky.com/help/articles/set-up-hub-max-hub-do-you-have-internet-calls
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
