Discussion topic: Hub security
Message posted on 31 Mar 2024 01:42 PM
Hub security
Just moved to SKY hub/broadband, received a call from SKY to tell me the hub is set to public. Agreed for them to call back-they said 30 minutes.
Three days later and noooooo callllll
tried online help with no luck.
now what?
Message posted on 31 Mar 2024 01:45 PM
Re: Hub security
Three days later and noooooo calllllltried online help with no luck.
now what?
Sounds like a scam to me. Sky doesn't contact customers on such matter or is there any setting to change to private
Message posted on 31 Mar 2024 02:01 PM
Re: Hub security
@Kenny+Fedup I would agree woth @cookiemonsteruk this sounds very much like a potential scam.
No ISP would actively call you, and no ISP would tell you your hub needs to be set to public as on Sky hubs there is no such settings.
Are you having a specific issue with Sky Broadband?
Message posted on 31 Mar 2024 02:02 PM
Re: Hub security
I agree with @cookiemonsteruk : 'set to public' doesn't really have any meaning in this context unless the router has manually been configured by the user to have no encryption, and an ISP wouldn't call their customer under those circumstances (they very rarely do at all)
Message posted on 31 Mar 2024 05:19 PM
Re: Hub security
The hub works fine. I get 'this site not safe' when going onto internet. Even sky.com
the caller actually said the router/hub was set to public and needed to be taken off that setting.
will call sky in the morning
Message posted on 31 Mar 2024 05:56 PM
Re: Hub security
There is no such setting.
Message posted on 31 Mar 2024 05:58 PM
Re: Hub security
They're getting round to duping you into downloading remote desktop software
Message posted on 31 Mar 2024 05:59 PM
Re: Hub security
Thank you so much ☺️
I think I should report this to Sky in the morning
