5
This discussion topic has been answered Discussion topic: Hub replacement
This message was authored by: Maureen+sky
Hub replacement
I have had my hub for 14 years , my wi fi keeps going and weaker. Can I have a new up to date hub no charge.
This message was authored by: jamesn123 Answer
Re: Hub replacement
@Maureen+sky
That makes no sense, your router can't be 14 years old if you have the Sky Q hub as it was only released in 2016.
The Sky Q hub is still the current router for anyone who does not have Sky VOIP calling, Full fibre or Sky Boost.
I am NOT a Sky Employee
Re: Hub replacement
@Maureen+sky
Which hub do you have at the moment?
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for Maureen+sky
Re: Hub replacement
Q box hub. (8 years old) But the router is 14 years old doi need a new router.
Re: Hub replacement
@Maureen+sky
Re: Hub replacement
Sky have sent me a new hub but I cannot connect it. Sky told me when the new hub is in I have to reconnect all my devices in my house with passwords etc. is this right. Also I asked if they could send an engineer out to connect the new hub because I have not got a clue. Then I will send the old one back. But sky said they do not send engineers out. So what's the point of a new hub. Also is the newer hub going to be better than the o,d hub.
Re: Hub replacement
@Maureen+sky
Why cant you connect it? Which step are you struggling with?
Maybe post a picture?
