Discussion topic: Hub dropping out
This message was authored by: Dazza26
Hub dropping out
3 days now our service keeps dropping out, all tests have been done and we're still having the same issue, is there a problem in this area?
Re: Hub dropping out
@Dazza26 Run the check and it may give you some idea, your area is unknown!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to displayed by the software test! This should determine if there's an identified fault affecting multiple households.
Avatar for Dazza26
Been checking and testing each evening, and to no avail! I'd put our post code in oringinaly but had to remove it, we are in the Beeston area in Nottingham.
