2
This discussion topic has been answered Discussion topic: Broadband down again
This message was authored by: Jo9191
Broadband down again for the second time today 19.48
Re: Broadband down again
@Jo9191
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@Jo9191
Avatar for Jo9191
Hi ... Thanks for the advice, I've checked no issues apparently but my Sky app is down, devices at home not connecting, hopefully it'll solve itself soon enough 😌
