Discussion topic: Hub distance...
This message was authored by: CherylMc
Hub distance...
Hi, ive recently had an EV charger installed and had to have a good signal for them to sync it up. Getting my car in a couple of days so been checking the app to make sure everything's working okay but noticed the connection constantly drops. The RSSI is 90 when its connected so not good at all. I have sky booster so I thought it would have managed to reach. The router can only be in one spot in the house so moving it isnt an option. Any help is appreciated. Thanks.
Re: Hub distance...
@CherylMc Sky booster does nothing just having that as part off the package, it does allow you to get the NECESSARY hardware that is required to boost the signal around the home, so now you need to do that, it's a call to sky for you to get though!  The info is linked below for you to read about it all!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
