Discussion topic: Hub connectivity issues
Message posted on 09 Jun 2025 04:51 PM
Hi, the internet light on my hub is either off or flashing orange for the past 1.5 hours. I've turned the hub off and on again and it doesn't make any difference. I've completed the check on my sky account and it says everything is fine. But I don't have an internet connection. Can you help?
Message posted on 09 Jun 2025 05:12 PM
Re: Hub connectivity issues
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
