Discussion topic: Hub 4.2 sr204 ff900
This message was authored by: Qprfc221
Hub 4.2 sr204 ff900
Just goe on to ff900 with new 204 to replace 203. Works fine with 600+ to the hub but never more than 180 to anywhere on wifi even next to the hub. Is this as good as it gets or can I do anything to improve wifi download speeds other than hard wire to the hub. All 4 minis sky q and 2 hard wired laptops work fine but the tests shows huge shortfall on wifi. Will it get any better??
Re: Hub 4.2 sr204 ff900
@Qprfc221
The Sky Broadband Hub (SR203/204) from 2019 is an 802.11ac ('WiFi 5') wireless device and so is fundamentally limited compared to more recent hardware.
@Qprfc221 Unusual to get the SR204 for the SR203 normally the other way around swap wise, but have you tried all the Q and minis off especially if you have them all set as wireless wi-fi connection, you will see a lot dissappear if they are hotspot setup, but then you can wi-fi speed test near the hub to see how it goes!
