28 Aug 2023 02:22 PM
Hi
I've just got the sky WiFi max but I've still got a dead spot in my house how do I get the sky pod extenders?
28 Aug 2023 02:24 PM
Posted by a Superuser, not a Sky employee. Find out more@Daz7189 Give Sky a call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
28 Aug 2023 03:01 PM
Posted by a Superuser, not a Sky employee. Find out moreApparently Sky will supply one pod on request, and up to two more after an installer visit.
Note that the current software release appears to be somewhat problematic.
06 Dec 2023 07:47 AM
Hi,
Did you get any pods when you did the order? I've also just ordered the max and not sure how many pods will be sent with it.
06 Dec 2023 08:42 AM - last edited: 06 Dec 2023 09:01 AM
No separate booster hardware is sent out with either Broadband Boost or WiFi Max: only the appropriate Hub is despatched. A booster unit is claimable retrospectively through a phone diagnostic if the target wireless coverage (3Mbs for Boost and either 10Mbs or 25Mbs for Max) isn't met, and additional booster hardware may be loaned following a 'wireless engineer' visit.
