Discussion topic: How to improve wifi connection
Message posted on 28 Jul 2025 09:04 AM
My wifi connection is terrible in my room mainly because where the box is connected to is in bad position that i cannot change.
What should i do to improve the speed
Message posted on 28 Jul 2025 09:52 AM
Re: How to improve wifi connection
@Ra26 if ghe hub definitely cannot be moved you will need a wifi extender which should be placed halfway between the hub and your room.it is best to get one mateched to your hubto avoid interference and mobiledevices having to connect to a second network. Sky will sell you a package called Sky WiFi Max which can supply extenders if requires see https://www.sky.com/help/articles/sky-wifi-max
The alternative is to buy your own equipment and use that instead of the Skyhub's wifi. If it is only one room an alternativecis to buy a Powerline Netwrking kit that uses your home's mains wiring to carry the signal. The adapters can be bought with built-in wifi access points as well as ethernet ports.
