05 Aug 2022 03:30 PM
Hello
just had sky broadband super 35 installed but I don't know how to connect my Epson ET-2500 printer
dummy with anything technical, so would appreciate any simple basic help,
thank you
05 Aug 2022 03:34 PM
You may need to seperate the wifi bands and set up the printer on the 2.4ghz wifi
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
06 Aug 2022 10:13 PM
Thank you
all sorted !!!
found WPS on hub, and done
07 Aug 2022 08:17 AM
Posted by a Superuser, not a Sky employee. Find out more@Vicky+62 Glad you sorted your issue and wps is the easiest method if the device you are connecting supports it..
For anyone else with the same issue WPS is on every Sky hub - the button can be difficult to see its on the right side of the upright hub. Just set the device to search using wps then press the button on the hub until it starts flashing.
Most newer printers dont need the wifi bands split.
